checking
/ checking #1
ihuntbear
new brunswick, canada
2015 tym T554 and 1999 Kobota m4700
how many of you have a problem seeing the hydraulic fluid on the dip stick.in the old days we used to put a little trans fluid in for color but now the dealer says if i do it voids the warrenty.all the hydraulic fluid around here is clear in color.I called the hydraulic repair guys today they recommended adding food coloring.Food coloring is water based.what do you guys use?????
/ checking #2
Man some times I have to put the stick in several times and hold it up just right to the light at the right angle. I would go with a bright flashlight or magnifying glass before messing with the oil. Not what you wanted to hear eh.
/ checking #3
you can get oil tint from JD.. or drill a 1/16 hole in the dipstick.. both work.
soundguy
/ checking #4
Takes a little patience but I a paper towel.
Pull the dipstick out and then slowly slide the towel down until you see it start to change color from oil absorption. Toilet paper or kleenex work well just be sure to get all of the lint/fuzz off of the dipstick.
Roy
/ checking #5
I have this same trouble so I always slide my thumb along the stick until I see oil begin to pile up in front of my thumb.
/ checking #6
Here is the info for the JD red dye:
Part Details
Part Number:
MT3668 Part Price: 3.91 USD On Hand:
0 Check Other Stores Description: FLUID, HYDRAULIC OIL DYE
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2005 Chevrolet Suburban SUV (A64194)
2005 Chevrolet...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A67147)
2005...
