Checking tire pressure with liquid ballast
   / Checking tire pressure with liquid ballast #11
   / Checking tire pressure with liquid ballast #12
Ballast Star offers Citrastar, a "chloride product with a citrus-based rust inhibitor". But is it lemony fresh?
Benefit over beet juice is mentioned but not clarified in the least. If gumming up gauges is from not using them right, gopp is still goop.
The Milton gauge may be nothing more than having no components that will rust. Instructions for use are the same as with any gauge.
   / Checking tire pressure with liquid ballast #13
Benefit over beet juice is mentioned but not clarified in the least. If gumming up gauges is from not using them correctly 'goop' is still 'goop'.
   / Checking tire pressure with liquid ballast #14
Most cheaper tire gauges are "close" but not 100% accurate. With filled tires you can use a regular pencil style gauge, just wash it out.
And yes, there should be air coming out if the valve stem if its at the top. Too much ballast can cause issues with the tire. There needs to be some air. I was always told 80% ballast / 20% air is good.
Just put the stem at the top and let some ballast out then add air. Keep repeating this until its just air coming out the stem. Don't let too much out at one time or you will drop below the recommended level.
I just fill my tires with water, but I am in Texas (tires don't freeze). I made this video on how I do it if you want to see: Easy Way to Fill Your Tractor Tires with Water - YouTube
   / Checking tire pressure with liquid ballast #15
. ........Some people will instead put some air in the tire, to clear liquid out of the valve........
I had read this tip on the forum and used it a few weeks ago. Worked great.
   / Checking tire pressure with liquid ballast #16
Here's a picture of my most favorite air pressure gauge from Harbor Freight.
Just blow it out after measuring a tire with liquid in it.
Ralph
So just to update this thread, I ended up jacking up the rear of the tractor while on a level concrete pad outside my garage. Then I moved the valve stems to 12 o' clock, removed the valve stem cores, and let all the excess fluid rush out. This process took 15 minutes or more. I got the fluid level to the point where there is nothing running out of the valve stem at 12 o' clock, but at 11 or 1 fluid starts to trickle out. To me this indicated that the fluid level is at the top of the wheel, but not above the wheel. Then I reinstalled the valve stem cores and inflated the tires to 15 PSI with the stems still at 12 o' clock. I was able to check the pressure with a pencil gauge with no fluid coming out of the valve stem. I got both sides to 15 PSI and then lowered the tractor back to the ground.
Manual calls for 20 PSI but I like a softer ride and better traction. We'll see how it goes. The tires should be somewhere in the ballpark of 60% full of fluid I'm guessing. I think these 43x16.00R20 tires hold 40 gallons @ 75%. So I'm thinking there should still be at least 30 gallons still remaining in each tire.
While the tractor was jacked up, I was surprised at how easy it was to spin the tires by hand. I expected them to feel very heavy with all that fluid in them. Turns out I couldn't tell there was fluid in them at all. This makes me think that the liquid ballast may not rob horsepower nearly as bad as suitcase weights or wheel weights due to how the physics all works. But that's another thread for another time.....
   / Checking tire pressure with liquid ballast #18
Sounds like good instructions to me:thumbsup:
PALLET OF ROUND STOCK (A52708)
PALLET OF ROUND...
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
We do NOT accept credit cards as payment. (A57148)
We do NOT accept...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58216)
2014 AMERITRAIL...
2015 FREIGHTLINER CASCADIA DAYCAB (A58214)
2015 FREIGHTLINER...
2017 Ford F-350 Utility Flatbed Truck (A56858)
2017 Ford F-350...
