Tires Checking tire pressure with beet juice in them
   / Checking tire pressure with beet juice in them #1
2funkids
Middleville, mi
Mahindra 3016 HST
I rotated my tires so the valves are at the highest point but beet juice still comes out of the valve stem. How do I check the pressure? I have an issue because I discovered my rear rims are from different manufacturers and I suspect this is what is responsible for different tire heights if they are not inflated equally. I measured over the same qty of lugs and the outside circumference is different for sure. One is about a half inch taller than the other. I purchased the tractor in September. Should I call for warranty replacement to get two matching rims?
It's a Mahindra 3016 with 72 hours.
   / Checking tire pressure with beet juice in them #2
Yes call your dealer about the rims and tires. Check air pressure just put the value stem on top and touch the value stem core just to clear the core out. The check the air pressure like normal.
   / Checking tire pressure with beet juice in them #3
Use a dial gauge that senses pressure with a Bourdon tube. They are immune to fluid. ... Measure at the top like youre doing because the pressure is greater as the valve gets lower.
   / Checking tire pressure with beet juice in them #4
Give the valve stem a quick blast with the air compressor to clear it out.
   / Checking tire pressure with beet juice in them #5
Never herd of checking pressure with loaded tires... Always filled them up completely... if ones sagging ad air if one feels to have to much pressure.. let some out
I sent pictures to my dealer (Burnips) showing the differences in the wheels and tires. I calibrated the tire pressure using the proper gauge and the right tire is wider and 1/2 shorter than the left. Without equal rims this is impossible to fix even with a new set of rubber. I have been waiting for a response for two weeks. So far it's with the Mahindra rep.....
   / Checking tire pressure with beet juice in them #7
I never fill my tires to more than 75% full...
BUT, I bought an air pressure gage from my CIH dealer that let's you accurately check the tire pressure whether there's fluid in them or not...
SR
   / Checking tire pressure with beet juice in them #8
TSC has a pressure gauge made for filled tires.
   / Checking tire pressure with beet juice in them #9
Wow, how'd this happen? Are these industrials? Just before I pulled the trigger on my 3016, I noticed the tires on a 3616 were larger even though it was the same frame tractor. Even weirder, was the fact that the same size tires on a 4010 as listed on the tire, were appreciably larger than the same stamped tire size on the 3616. So is one to believe that rims from either tractor would fit either tire? I measured the rims on the 4010 and they also were larger than the 3616 with the same stamped tire size. One would think that a specific tire size would all go on the same dimension rim. As there is no standard to actual tire sizes, it makes matching needing to be a bit more scrutinized at times. Glad you caught the issue and you should have little trouble with a resolve as this is blatant oversight at some point of distribution.
Yes, I am using the gauge for liquid filled tires and these are industrial tires.
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
1982 MACK RD685S HOTOILER (A50854)
1982 MACK RD685S...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
