Tires Checking the inflation of loaded tires
   / Checking the inflation of loaded tires #11
Yep.. and if not flushed well.. it can leave crustals that gum up the works..
soundguy
   / Checking the inflation of loaded tires #12
If the tire looks the way it always has, and puts a full tread on the floor, why keep checking it? If it starts to look soft or leaves a puddle then you KNOW is leaking....
   / Checking the inflation of loaded tires #13
DO NOT use your good inflater / pressure gage combo deal! I used mine (you know the ones where it shows the pressure as you are inflating) and it was toast. Gurrrr
   / Checking the inflation of loaded tires #14
I've got a few cheappy gauges I use for checking filled tires. I always flush them good with fresh water and in 20 years only had one gum/rust up. So, I'd say don't use a nice gauge, but also flush the one you do use and it should last you a good long while. If you don't flush, next time you go to use it'll be trash...
Also, I always check my print in the dirt with and average load on the rear. If I'm getting full contact, then it's right, but not too much "bulge" on the side walls.... You kind of gotta get used to what to look for, but in general the specs in the manuals are too high....
(27) Cones w/Barrier Flags (A56469)
(27) Cones...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
Bomag BW213D Smooth Drum Vibratory Soil Compactor (A55851)
Bomag BW213D...
2 Cubic Yard Dumpster (A55851)
2 Cubic Yard...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2012 CATERPILLAR 308E CR EXCAVATOR (A52707)
2012 CATERPILLAR...
