Checking pump timing
   / Checking pump timing #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
Is there a easy way to check the injection pump timing on my 1900 without dissassembling the engine. I know the previous owner had the engine apart. I don't see where they marked the pump and cover for reassembly. My service manual shows how to set it with the engine dissambled but not while assembled. I just want to make sure it is correct. When you look at the adjustment slots on the pump it is turned all the way counter clockways which leads me to beleive it may not be set right.
Bill
   / Checking pump timing #2
Bill
Bill,
I have not done it before but briefly read the direction in the past. There is a notch on crankshaft pulley that shows #1 piston on TDC where it lines up with the a metal pointer on the block. A bit ****** of that is another notch where indicate the injector pump release. I thought it said to break the fuel line to the injector and as you turn the crank shaft slowly with a breaker bar it should begin to discharge the fuel. fine adjustment is done by loosening the injector pump from the timing cover and advance or forward as it needed.
What I have done on mine is to put a witness marl on the pump using my dremel tool on two locations for future benefit.
I know you have the manual but if you want I can post it.
JC,
JC I have looked in both service manuals and can not find how to check it unless I am looking in the wrong section (fuel sys). I would apriciate it if you could post it or email it to me. Thank you
Bill
   / Checking pump timing #4
Bill
Bill,
Take a look at the document below to see if it helps you. It starts from the middle of page 46. It is about the same as what I suggested.
JC,
Thanks JC. That info helped alot. I will print it and add it to my manual.
Bill
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2014 Buick Lacrosse (A52384)
2014 Buick...
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
