Checking My Alternator With A volt/ohm Meter
   / Checking My Alternator With A volt/ohm Meter #1
futuorganics
I was told to check my alternator first. Thanks? I am on my way to the auto parts store and farm now. I want to make a habit of asking first sooooo. How do I use the meter and what am I looking for? 13.6 volts refers to what? /forums/images/graemlins/confused.gif
   / Checking My Alternator With A volt/ohm Meter #2
From the Hoye Tractor site:
Your Yanmar tractor not keeping the battetry charged? Chances are the regulator is bad. Yanmar uses an extremely reliable "generator" unit that, unfortunately, uses an unreliable external regulator.
To test the generator you need to use an AC (like a house voltage, not a car) volt meter. Locate the two wires coming out of the generator and follow them to a small plug. After disconnecting the plug, hook the ground wire from the meter to one wire and the posative to the other (it doesnt matter wich one). With the tractor running at a medium idle, you should have either 14VAC or 40VAC (+-). If it is anywhere close your generator is OK. If your generator is broken you will not get any voltage at all.
Check to be sure that all of the wires look OK from the generator to the regulator and also to the battery. If all of these are OK, your voltage regulator has likely burned out. There is no way to repair these units. You can find replacement regulators here.
   / Checking My Alternator With A volt/ohm Meter #3
What model Yanmar do you have. The test procedure depends totally your model.
2008 Caterpillar 45kW C4.4 3-Phase T/A Towable Diesel Generator (A51691)
2008 Caterpillar...
2003 International 4200 Box Truck (A51692)
2003 International...
2015 International DuraStar 4300 Ambulance (A51692)
2015 International...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
