checking hyd fluid ?
   / checking hyd fluid ? #1
redka
Middle GA
JD 5403, is the hydraulic fluid level supposed to be checked(cold) before starting the tractor or after it's running and warmed up. The operator manual is not clear on that to me. Thanks
   / checking hyd fluid ? #3
Your dipstick should have a cold and a hot level. Low level for cold and as your tractor heats up the fluid will expand to the higher level.
   / checking hyd fluid ? #4
Not on a JD it doesn't. It should have a sight glass right beside the PTO shaft. Make sure the tractor is level front to back and side to side.
   / checking hyd fluid ? #5
I knew that some Deere's had sight glasses but did not think the 5403 was one of those models.
No HOT or COLD on the dipstick...just FULL. Don't think there is a sight glass but will check tomorrow.
   / checking hyd fluid ? #7
If you have a dipstick you should have a low and high mark. Low is for cold and high is for hot. Does it not have a knurled area that gives you a range?
   / checking hyd fluid ? #8
My 5303 has the high/low marks on the dip stick, i always check cold.
Ronnie
   / checking hyd fluid ? #9
Also another thing, have any attachment hydraulic cylinder retracted.
(INOPERABLE) SULLAIR (A45046)
(INOPERABLE)...
2011 BEALL TRAILER PNEUMATIC TRAILER (A45333)
2011 BEALL TRAILER...
Kubota SVL97-2 (A44501)
Kubota SVL97-2...
2013 Kenworth T400 Truck, VIN # 1NKBH27XXDJ351951 (A44391)
2013 Kenworth T400...
2010 TEXMEX  UTILITY TRAILER (A45333)
2010 TEXMEX...
2018 GMC SIERRA 2500HD (A45046)
2018 GMC SIERRA...
