Checking front axle fluid on a CK30
   / Checking front axle fluid on a CK30 #1
cwb440
2007 Kioti ck30hst
Calles for 1.19 gallons, but after draining completely, and putting in 4qts, it looks over the red dot in the sight glass. So I didn't put in the other quart but it makes no sense. Any experience with this? Also, I have not run it after filling, maybe it will go down?
   / Checking front axle fluid on a CK30 #2
You do realize that there’s 4qts in a gallon? And yep, it might need a little bit of driving to settle the oil. However, you only need to add .19 of a gallon, or 2/3s of a quart if you got the old oil completely out. Probably there’s some residual…😉
Thanks, yes, I was expecting to need to add the 2/3's of a quart and then saw that it was already full. It was confusing because i even left the drain plugs out over night to make sue it all drained out. The capacity is in the manual at 1.19 gal but sometimes "drain and fills", which was not listed, are less because of residual. I will check it again after running it.
Update, after operating in 4wd, and letting it sit for a day, the level came down and it took another 1/2 quart.
New Idea 484 Round Baler (A50774)
New Idea 484 Round...
9202 (A50322)
9202 (A50322)
Bush Hog 84in Rotary Cutter (A50322)
Bush Hog 84in...
KUBOTA KX91-3S2 SUPER SERIES 2 EXCAVATOR (A51242)
KUBOTA KX91-3S2...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
