Checking for sludge in the fuel tank question
   / Checking for sludge in the fuel tank question #1
STxGardener
N/A
So I decided to go with the purchase of an older model (2022) Yanmar SA324 tractor and am concerned that there may be a chance that sludge in the fuel has had time to develop as the tractor has been on the lot for a period of time. So I wondered if there is a good way to test the tractor fuel tank to see if any biological sludge is present and growing in the tank. I will probably use a biocide to protect against the fuel developing sludge but how would I check the tank when I receive delivery of the tractor? TIA for any comments or suggestions.
   / Checking for sludge in the fuel tank question #2
Lots of ways to check...
If it's a straight shot to the tank bottom, use something to scoop the bottom of the tank and see what you get. Or use a vacuum pump to suck some off the bottom. If that's not possible, remove the fuel line at the tank and see what comes out.
With a contaminated tank there will likely be crud present in the fuel filter or sediment bowl, assuming the tank outlet didn't clog first. Microbial contamination will appear as a dark slimy goop.
   / Checking for sludge in the fuel tank question #3
An 'inspection camera', put down into the bottom of the tank, will show you whether there's a biological growth or not.
   / Checking for sludge in the fuel tank question #4
There are test kits for presence of water in fuel tanks. No water then there's no fungus in fuel tank
Well, older was probably the wrong word. It's just not a brand new, recently built tractor and has had time to sit on the lot for over a year.
   / Checking for sludge in the fuel tank question #8
I wouldn't worry about it but you can check the fuel filter bowl if it has one. How long does heating oil sit in those tanks??
NEW Fork Extensions (A59000)
NEW Fork...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56435)
2007 Heil Heavy...
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
