Check your ML108H Clamp Bolts
   / Check your ML108H Clamp Bolts #1
dieselsmoke1
Platinum Member
Eastern North Carolina
Mahindra 2810HST
Maybe I'm just too heavy handed. While mounting the FEL today and cinching the clamp bolts with a 1/2" ratchet, I popped the head off one of the bolts. Closer inspection showed the bolt cracked about half way through just below the head. Checked the other bolt, also had a mark which could be a stress crack. Consider myself very lucky to have found this with a wrench and not a bump. Just thinking about all the bad stuff that could happen if one or both clamp bolts failed with a loaded bucket gives me indigestion.
   / Check your ML108H Clamp Bolts #2
thanks for the info. I kinda thought the bolts on my ML106 FEL looked a little weak:eek: . I will be checking mine tomorrow!
   / Check your ML108H Clamp Bolts #3
I've replaced some of them with hardened bolts, as I have seen them let loose.
   / Check your ML108H Clamp Bolts #4
It may have been one of cheap bolts (like the cheap $0.39 snap pins) that are made in India.
   / Check your ML108H Clamp Bolts #5
Thanks! I think I'll be replacing mine.
   / Check your ML108H Clamp Bolts #6
Help me here. I've looked through the loader manual, and nowhere do I see clamp bolts. Can you be more specific please? Is that really what they are called?
   / Check your ML108H Clamp Bolts #7
I am sure they are talking about the bolts that go through the "hinge" that clamps the loader onto the rear mounts.
   / Check your ML108H Clamp Bolts #8
Would that be the vertically installed carriage bolt assembly?
   / Check your ML108H Clamp Bolts #9
Yes. I was trying to come up with the better description and part number from memory, but came up empty. Been a LONG week for me. I could have turned around and grab my manual book off the shelf, but couldn't even get myself to do that...:(
The local hardware store didn't have hardened bolts so I had to get mild steel as a temp fix. I'm going to Fastenal tomorrow for hardened ones.
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
CAT 973 (A47384)
CAT 973 (A47384)
2015 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
UNUSED FUTURE SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED FUTURE SKID...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
