Check your ML108H Clamp Bolts
   / Check your ML108H Clamp Bolts #1
dieselsmoke1
Platinum Member
Eastern North Carolina
Mahindra 2810HST
Maybe I'm just too heavy handed. While mounting the FEL today and cinching the clamp bolts with a 1/2" ratchet, I popped the head off one of the bolts. Closer inspection showed the bolt cracked about half way through just below the head. Checked the other bolt, also had a mark which could be a stress crack. Consider myself very lucky to have found this with a wrench and not a bump. Just thinking about all the bad stuff that could happen if one or both clamp bolts failed with a loaded bucket gives me indigestion.
   / Check your ML108H Clamp Bolts #2
thanks for the info. I kinda thought the bolts on my ML106 FEL looked a little weak:eek: . I will be checking mine tomorrow!
   / Check your ML108H Clamp Bolts #3
I've replaced some of them with hardened bolts, as I have seen them let loose.
   / Check your ML108H Clamp Bolts #4
It may have been one of cheap bolts (like the cheap $0.39 snap pins) that are made in India.
   / Check your ML108H Clamp Bolts #5
Thanks! I think I'll be replacing mine.
   / Check your ML108H Clamp Bolts #6
Help me here. I've looked through the loader manual, and nowhere do I see clamp bolts. Can you be more specific please? Is that really what they are called?
   / Check your ML108H Clamp Bolts #7
I am sure they are talking about the bolts that go through the "hinge" that clamps the loader onto the rear mounts.
   / Check your ML108H Clamp Bolts #8
Would that be the vertically installed carriage bolt assembly?
   / Check your ML108H Clamp Bolts #9
Yes. I was trying to come up with the better description and part number from memory, but came up empty. Been a LONG week for me. I could have turned around and grab my manual book off the shelf, but couldn't even get myself to do that...:(
The local hardware store didn't have hardened bolts so I had to get mild steel as a temp fix. I'm going to Fastenal tomorrow for hardened ones.
UNUSED JCT QUICK ATTACH BACKHOE DIGGING ARM (A51244)
UNUSED JCT QUICK...
2018 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2012 Hyundai Sonata LIMITED (A50324)
2012 Hyundai...
2016 Ford Explorer...
2018 JOHN DEERE 310SL HL BACKHOE (A51242)
2018 JOHN DEERE...
UNUSED FUTURE 12' X 7' CONTAINER (A51244)
UNUSED FUTURE 12'...
