BlacknTan
Platinum Member
Are check valves available to add in line to a hydraulic top link? How do mfgrs other than CCM stop their valves from leaking down?? There must be devices that could be added... No??
They don't...How do mfgrs other than CCM stop their valves from leaking down??
It's the style of valve being used which leak down. I can show you applications without dpocv's that absolutely do not leak down. Get the right high quality valve and they don't leak down. A valve seals by the same principals as a cylinder. It's all in the seal style and configuration. Most valves on your CUT's don't even have internal seals, this is why they leak down.
Could someone point me in the direction of a high quality cylinder that does not need a check valve to prevent bleed down??
PM if you feel the need..
As Andy said, its not necessarily the cylinder, but the spool valve that leaks and causes the cylinder to move. Why do you seem opposed to the CCM unit? It's certainly a proven system...
Is there any other cylinder on a tractor with a check valve?
