Check valve vs backflow preventer
   / Check valve vs backflow preventer #11
You have been given the options and now you must decide if your families health is worth the expense of a $300 back flow preventer that is Code Compliant for municipal water districts or if you want to go cheap with a check valve system. In either case, install them above grade by at least 12". At minimum I would go with the air gap type that drains the piping so as to prevent a siphon rather than just check valves.
My back flow preventer on my sprinkler system has to be tested by a certified agent yearly to assure it is working correctly. This year I had to replace a $175 part (basically all the guts of the thing) to keep it from leaking. Mine has a brass frame that allows quick replacement of the working parts of the preventer using just a screwdriver so I saved about $100 by not having to put in a whole new part.
   / Check valve vs backflow preventer #12
Might be cheaper just to buy your family bottled water! I mean, how much cold water do people actually drink?
Learning how to do this the right way the first time is why I posted the topic. Some here seek the least expensive way; that is not my mode.
I appreciate the very good replies and my knowledge of how to get it done right has increased a lot. I noticed the Zurn/Wilkins 375XL has a "blow out port" that says it is useful if used for irrigation systems, or for winterization. I'm looking very hard at putting that model in, along with a screen and drain. Since there is expenditure in money and labor for installation, I only want to do this once so I want it right.
   / Check valve vs backflow preventer #14
I was a licensed irrigator for many years, the simple answer is a check valve can't be tested and a backflow prevention valve can. Get the BPV, either an RPZ or a PVB, depending on your elevation changes. PVB needs to be installed 12" above the highest part of your system.
   / Check valve vs backflow preventer #15
I am a bit confused at what can be above vs. below grade, compared to being in the "high spot" of the irrigation system. Here is more about my system:
1. The irrigation piping is both above and below the elevation of my well. The area where I want to make the connection of the well drinking water PVC pipe to the irrigation pipe is slightly below the elevation of the well. So, my connection can never be above the highest spot in the irrigation piping system
2. I get contaminants (bugs, etc.) in the irrigation water supply from time to time. Never any visible contamination in the well water supply.
3. My well consistently applies 50-60lbs of psi in the piping. The irrigation system psi varies whether I am at a high or low spot in the piping. At the area I want to make the connection the irrigation psi is 32psi maximum. (About 10 psi more at the lowest part of the irrigation piping.)
4. I will shut everything down and drain all lines at the end of the season. So minimal frost protection for any above grade components should be OK since I would only be protecting against a surprise frost. Lines will be drained before the coldest temperatures arrive.
The "reduced pressure zone backflow preventer" suggested above is about $800 at Grainger. Or a 1" backflow preventer is about $125 at Lowe's. They look visibly similar but I am guessing the more expensive one must be more capable?
I also found these items for sale online:
1" Watts LF009M2-QT Reduced Pressure Zone Assembly. ($284.14)
Air Gap Drain Fitting #909-AGC (+ $61.80)
1" Brass Wye-Strainer (+ $57.00)
btw, thank you for suggesting the addition of drains and pressure gauges to the manifold.
Been working on my system or I would have responded sooner. There is a type of anti-siphon/vacuum breaker valve used for irrigation. As they are open to atmosphere they must be 12" above grade also. The only approved ones have test connections same as other devices. Testing requirements are the same. The cheap ones are only used as vacuum breakers to allow drainage. A reduced pressure type is the best and most reliable. It is required for facilities where chemicals can be introduced, in medical facilities, and connections to equipment containing water treatment chemicals. Some jurisdictions require them at facility entrance mains to protect their water system and the neighbors. Double check is generally used for irrigation and places like piers. Check valves are not approved. Pecking order of reliability is same as how the prices range.
I always put my circuits in a loop so there is equal pressure at all points all the time. I use the pressure reducer to maintain a constant pressure through fluctuations in delivery pressure and that most design criteria call for 40-50 PSI for irrigation. Main supply pressures can be as high as 100 PSI+ and irrigation parts are not designed for that. A lot of folks use thin wall PVC also to save a few $. My minimum for mains is 1" schedule 40 PVC with 1/2" branches. Never a flow problem. There is more information on the web than you can absorb in a short time. It is a complicated subject and plumbers have to have training and be certified to perform inspections and certifications.
Hope this clarifies. Ron
I have roughly 60psi from the well, using 1" schedule 40 pvc. Where I want to connect that to the irrigation system, I have only 32psi (max) in a 1 1/2 schedule 40 pvc pipe. The well pressure is constant, the irrigation pressure is variable since it is gravity fed.
I will install a reduced pressure backflow preventer to protect the well. I learned that all of these inherently reduce pressure from the supply side to the output side, which is no problem since I am starting with about 60psi. If it reduced that to 50psi I still have far more pressure from the well than from the irrigation lines, but that also introduces a problem.
I would like the irrigation water to be "priority," (when it is available) and use the well water only for backup. When irrigation water is present, it is "free" since it is gravity flow, whereas the well is not. But if I just use a Tee to connect them together, I will be connecting two pipes together where the well has much more psi (always) than the irrigation lines. I presume it would therefore always be running as the "primary" supply which is not what I want.
I'm looking at adding a Zurn 70xl pressure reducer after the backflow preventer. I would use that reducer to reduce the psi from the well supply down to 25 psi, or some other (any) setting below the normal operating pressure of the irrigation system. I'm hoping that when irrigation water is present, with 32psi, it will then automatically be the primary source since it has more pressure than the well psi which I have downgraded. But when the irrigation water degrades, losing psi, once it falls below 25psi the well would kick in. I've never done this before but am presuming that would work?
Final note: Where I want to Tee in and use the well as a backup only runs small demand things like lawn sprinklers or drip irrigation. That stuff runs fine at 32 psi, so I presume/hope it would also run at a little lower psi which I would set the well output to. I have other irrigation "things" that require more psi, but that's not in this location.
   / Check valve vs backflow preventer #17
Do you want change over to be automatic or manual? Valves will suffice for manual change. You need put a check valve in the irrigation line to prevent the well pump from back feeding into the irrigation source. You need a fine strainers ahead of all valves in both water source lines clean water to devices. Thy all have small passages that clog easily. To make it automatic; put a solenoid in the well line and a flow sensor in the irrigation source line that operates the solenoid. Tonight I will work on a flow diagram for this, maybe. I would use a double check back flow preventer if mine. Your choice. Keep all your piping clean as you go and flush well before installing heads. Shop your devices. Stay with known brand names and any will give good service. Prices are allover the map as these items have good markups and overheads vary much. I use Amazon a lot. My church gets a doby on all my purchases there. Usually cheaper than the big box stores.
Ron
Very good information, thank you. Yes I would like the switchover from irrigation water to well water (when needed) to be automatic, if possible. That's why I had considered reducing the well output psi to something below the irrigation system psi.
I agree that a check valve is needed to prevent the well from attempting to pressurize the entire irrigation system infrastructure, and only pressurize the single "circuit" that I need. I am looking at adding a flow meter on the 1" well supply so I can monitor just how often the well is supplying irrigation water, and in what volume.
I am homing in on Zurn/Wilkins products as they seem high quality. I have not shopped or researched strainers, and I should do that as the irrigation water sometimes has debris including small bits of frogs in it. :frog: Can you recommend any strainers that would fit on 1" and 1 1/2" pipe?
   / Check valve vs backflow preventer #19
Amazon has Zurn products in 1" pipe size. They also have 20 Mesh strainers if you want to sty with Zurn. I used a plastic body made for irrigation strainer/filter. Not very expensive on Amazon, will look for it in the archives and get back. Unless you are using 1 1/2" pipe for the main laterals I think 1" is a large as you need to go, throughout. A 1/2" equalizer line back on for each loop will assure even pressure at all heads in that loop. In reviewing your scenario I do not see you having a big contamination potential. I would be more than comfortable with the double check valve and save the $100+.
In case others are following this thread; those vacuum breaker units have to be the "pressure" type. That's the ones with the test cocks. The others tend to leak under pressure. They also need to be inspected and certified where allowed by the AHJ.
Well, back to my system.
Ron
2007 Ford Five Hundred SEL Sedan (A55853)
2007 Ford Five...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
2023 yamaha (A55758)
2025 MAMMOTH SB-2 2025 SAND BOX TRAILER (A56129)
2025 MAMMOTH SB-2...
2005 Eager Beaver 20XPT (A47477)
2005 Eager Beaver...
