Check valve question
   / Check valve question #11
Flow restrictors should eliminate this issue. I recommend putting them on both ports.
A 2" cylinder, would get .031 restrictors.
   / Check valve question #12
Eric
With weight trying to extend the toplink cylinder oil will leak out of the rod end through the directional valve. This creates an air pocket on cap end of the cylinder since the vacuum will not pull oil through the directional valve.
The check will prevent the oil leaking through the directional valve and should solve the spongy cylinder.
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
Toro Mower (A56857)
Toro Mower (A56857)
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2018 Volvo MCT 110C (A55272)
2018 Volvo MCT...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
