Check those loader frame fasteners!
   / Check those loader frame fasteners! #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I was just "walking around the Hurlimann with the Allied 195 loader today. Two of the four front frame attach bolts were little more than finger tight. Thesplit lock washers showed the gap.
A minute with a socket wrench and bar snugged them back again.
Check early, check often ;-)
   / Check those loader frame fasteners! #2
Get rid of the split so-called lock washers. Replace with Blue Loctite.
   / Check those loader frame fasteners! #3
I had the right bracket front 2 bolts fall completely out, the first time I recognized they 'could come loose'. I found a spacer on the ground, and wondered "Where the **** did that come from?" I was shocked to see the right loader bracket loose up front. Luckily, the back was still solid.
Now, I check them and almost all visible bolts, each time I fuel up. If something looks like it could be loose, I go over everything in that size socket, that I am able to find.
I've had loader bolts loosen more than anything. But, I just had a bolt which holds up the fuel tank loose as well as 2 other which hold the 'brush guard' on. I'm amazed at how easily they loosen. I think that if I get an afternoon this summer, I'll add Loctite, hopefully that will decrease the issue.
   / Check those loader frame fasteners! #4
Agreed. I stopped using split washers, serrated, etc. long ago. For some reason I'm still a weak fan of nylock nuts on occasion but Blue Loctite is now a staple.
   / Check those loader frame fasteners! #5
You might want to check to see if those bolts have a torque spec.
   / Check those loader frame fasteners! #6
I've been torque checking my loader frame nuts every spring since I found one missing. Blue loctite too.
2022 Club Car...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2016 Ford Taurus SE Sedan (A48082)
2016 Ford Taurus...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
10x16.5 Tire Assembly (A51039)
10x16.5 Tire...
