sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,260
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Cold air contracts and the perfectly fine air pressure of the summer can drop low enough to cause problems in cooler weather. Cold air contracts and warm air expands; you can look it up.
You can actually slip a bead off the rim and I once did just that on a 12 ply ag tire. The bead/cord was so stiff I spent part of a day try to re-seat the bead. Then another part removing the wheel, hooking up the trailer and taking it to a truck stop to get it inflated. It was a Sunday so no tire trucks to call and I needed it now.
Recently, while hauling a bigger trailer, my dash lights told me my tire pressure was in the middle 20's on the truck and that surely would or could have created a dangerous tire roll or overweight tire issue. You would have thought I knew better.
Anyway, check and pump up all of your tires for the cooler weather and add a little more if going into winer storage. I even pump up radials because I've learned some brands or lines can actually develop flat and hard to remove spots from from sitting. My 7psi rears now have 21 lbs till spring. Just my free and hard-learned PSA while I'm waiting forever for the wife to get out of the shower. This is like shopping for shoes with her.
