Check light on with higher temperature
   / Check light on with higher temperature #1
Mattyboy936
Mahindra 3510
Hi guys, I had a “check” light that was on with a fuel solenoid issue and the stop light brake switch not working.
I still get the light on when my tractor is used for some time and my engine gets hot.
My question is.. is there a safety switch that causes that “check” light to go on if the engine is running hot?
My gauge will climb slowly up to the 3/4 line (line before hot) that’s when the light comes on.
I’m going to order a thermostat and I’m going to get it to a location where I can flush the system out and maybe hose off the fins of the radiator..
Coolant..
any antifreeze will do?
What does Mahindra recommend for year round mix? 50:50?
   / Check light on with higher temperature #2
You need to clear the radiator from the backside as the fins get packed full of debris. It may look clear, but can you see light through it? If you can't see light through it, the fan can't pull any air through it either.
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
72In FEL HD Round Back Bucket (A52128)
72In FEL HD Round...
2015 F-550 Bucket Truck. (A52128)
2015 F-550 Bucket...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A52128)
2019 Ford F550 4x4...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
TOPCAT SKID STEER QUICK ATTACH BRUSH CUTTER (A51244)
TOPCAT SKID STEER...
