3-Point Hitch Check Chain setup for Satoh Beaver
   / Check Chain setup for Satoh Beaver #1
mthielk
Fallbrook, ca
satoh s370d
I just got this Satoh Beaver. Quite a nice machine. The previous owner had the check chains on the inside of the lower arms. I moved them to the outside: see picture. Am I doing this right?
   / Check Chain setup for Satoh Beaver #2
That is the way mine are.
   / Check Chain setup for Satoh Beaver #3
That's the correct way from the factory, but be aware that configuation is not very strong. The rod ends will tend to bend with moderate side-loading of the implement. As long as you're aware of this (i.e. minimize side-loading) you should be fine. I broke mine backing up a trailer once at an angle using the 3-pt with a trailer adapter.
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
