Check ball laying next to transmission filter
   / Check ball laying next to transmission filter #1
Rexnfx400
Stanwood, Wa
YM186D
Hey guys,
Would you know where perhaps a 1/4" check ball could be from? It was laying next to the transmission filter/screen. Anyone know the paticular area this may be from, within the tranny? Maybe, its possible its actually a part of a bearing? If a bearing had come apart, then there sould be cage material also. I did just buy it. But, It looks as though the filter cover hasn't been off for decades. Just wondering if anyone had the same scenario. Everything is working correctly. Its a 186D 18HP
Thanks for any input...
Rex
   / Check ball laying next to transmission filter #2
There are only three 1/4" balls in the 186. All used in the trans. #17 , #11
&, #33 - .
Does it look like the tractor has been apart before?
Aaron
Parts@HoyeTractor.com
(940)592-0181
Hey Thanks! I'll have a look at those places. They look fairly accesible. I'm not sure if its been apart before. Hard to tell as the powertrain has all be repainted(touched-up)
Those are excellent diagrams. As the repair manual I got is a little poor on the copy quality.
Rex
Fixed!
Well, it all makes sense now. Its the detent ball for the 3 point lever. I didn't know a three point lever would even have a detent(total tractor noobie, I must confess). As the lever is held center with springs and bungy cords. So, now I know(or at least I think I know) the 3 point lever should have a detent ball #11. Thank you so much for your help Aaron! You put my mind at rest about the ball.
Rex
   / Check ball laying next to transmission filter #5
I initially had problems with that detent on my 186D. I couldn't get it to stay in place. I tried bending the arm that holds it on the lift lever as I thought this was the problem but never could get it to stay in place after I reassembled the tractor and cycled it a few times. I shelled out for a new lever and haven't had a problem since. It appears that my tractor had been rolled before I acquired it and I believe the lever must have been damaged slightly during the incident.
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
1261 (A50490)
1261 (A50490)
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
