Spreader Cheapest spreader that works well?
   / Cheapest spreader that works well? #1
JCA
Maine
Kubota B7510
I need a way to spread a salt/sand mixture on my private road, that doesn't cost too much. I've seen cheap tailgate versions ($150), but heard complaints because of the lack of an agitator. I want something that works reliably.
Freezing rain last night left the driveway a solid sheet of ice. The guy driving the sand truck lost it coming down the hill (they usually back down but this was a new guy), turned 3/4 way around and ended up with one wheel dangling over the edge of a 25 foot decline. Wasn't wearing his seatbelt. We got him out of there, but it was scary, even for me, and I wasn't driving. $45 / shot, btw.
So what do you use, how well does it work, and how much did it cost?
Thanks,
Jim
   / Cheapest spreader that works well? #2
Jim:
There are a couple of questions we need answers to. How long is your driveway (i.e. how much salt/sand do you need the hopper to hold)? and what are you going to mount the spreader on?
BigDave had an interesting post a few days ago on a Vicon he just bought. This is a 3ph PTO driven unit that looks like it will hold quite a lot of sand/salt in the hopper - maybe a quarter of a yard? Maybe he can fill us in on how much driveway he can do with a hopper full of sand. It has an wigwag speading arm and an agitator in the hopper.
At the other end of the spectrum I have a Byers tailgate type spreader mounted on my tractor - electric motor drives a spin plate. The hopper on my unit is fairly small - may 20 shovells full - and I have to refill it to do all of my 500 foot driveway. These are not cheap units - I think I paid about $US500 for mine a couple of years ago, but I think they have come down in price. There is no agitator in the tub which is a pain because sand stored outside holds a lot of moisture and doesn't flow down the tub very well. Thanks to some suggestions from others on TBN, I have started storing a few tote boxes of sand/salt in my basement to let it dry a bit. I have only tried using this "dried" method once but it worked quite well. Overall I am quite pleased with the Byers unit.
You can also get pull-behind unit, both as drop spreaders and as cyclone spreaders, and maybe even wigwag but I haven't seen one.
Hope this helps.
My driveway/private road is about 700' long. I intend to mount it in the 3PH of my Kubota B7510.
Cheers,
Jim
   / Cheapest spreader that works well? #4
I use a cone shaped 3PH broadcast spreader that is designed for fertilizer. It has an agitator that runs off the PTO. It holds about 400 or so pounds of sand. We had a lot of ice last winter, and it did a good job on my driveway.
It took a while to get used to sanding just the drive. The first few times I had the RPMs too high and sanded a 50 ft wide path. It worked best when I kept the RPMs low and kept the opening to the spreader about 25% open.
TSC has these for about $400 or so if I remember right. You can also find some high end spreaders that deal with frozen sand or gravel for upwards of $1,000. I do the same as HWP-Keep 50 pound bags of sand in my garage so it isn't frozen when I start. Hope this helps.
John
12' CONTAINER (A52706)
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2019 Chevrolet Silverado 2500 4x4 Warner Service Truck (A55852)
2019 Chevrolet...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
