Cheaper than ????
/ Cheaper than ???? #1
pat32rf
Bancroft, Ontario
JD4300
I have a set of oxy/acet torches out in the garage and I also have a little plumbers "B" tank that I use for smaller heating jobs and soldering. Been using the same bottle of gas for five years but I ran out last night. I know how the price of the bigger bottles have jumped and I am wondering if I might be better off switching to one of the fancy newer propane torches for my plumbing jobs...?
/ Cheaper than ???? #2
I have a couple Victor Propane Turbo torches and they work well. Actually they are Air Propane because they pull air from the atmosphere to help create heat. I like these but when doing larger copper pipe like 1" or larger, I go back to Acetylene air like your B tank or better yet get it over with by lighting the Oxy-Acet set. I like Oxy-acet when you need to re-do or add a joint close to one that is already there. You can heat it up and solder it quickly and get out without loosening up the whole system which could happen with a long drawn out propane heated joint. But. It all works. Some just faster than others.
/ Cheaper than ???? #3
If you are asking about using Propane rather than Acetylene depends on your tolerance level. I started with A and when I moved out here A wasn't all that accessible but P was so I changed tips and went with P. Hard to start and not as hot were my two dislikes. After my finances started picking up and stores got closer, went back to A.
/ Cheaper than ????
Our local plumbers all seem to use some form of propane turbo torch these days but back when I was working our choices for a hot flame were acetylene so I carried a company refilled B tank. I am now over 70 and don't much copper work anymore. I have lots of 1lb propane tanks and thought it might be cheaper to buy a turbo torch than refill the B tank.....but I can get a refill a mile down the road, a Turbo torch is 60 miles away at the welding wholesale.....
If I save enough I can pay my $700 hydro bill.....
/ Cheaper than ???? #5
Propane is cheaper and a lot easier to pick up than acetylene. I prefer to use the hand held ?16 oz propane canisters as I don't do that much soldering. I suppose if I were a plumber it would make sense to carry a bigger tank around and acetylene would be a reasonable option too.
/ Cheaper than ???? #6
For sweating copper for water lines using a hand held torch I like to use mapp gas...for silver solder (refer lines etc.) I use a 'B' tank...
40ft Shipping Container (A64194)
40ft Shipping...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2009 Ford Ranger XLT 4x4 Ext. Cab Pickup Truck (A61573)
2009 Ford Ranger...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
Deere 50D (A60462)
Deere 50D (A60462)
