Cheap, servicable trailer
/ Cheap, servicable trailer #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
I hesitate to post this little "project" because it isn't fine work like some posters entertain us with, but for someone looking for a small, inexpensive trailer, this might be of interest. I had an old trailer that was rotting and rusting away, and rather than rebuild it, I grabbed a 4' x 8' bed, 1195 lb. load capacity trailer "kit" that Harbor Freight had on sale, and with the 25% off coupon I had, it cost me all of $223. As I got into putting it together, I was pleased with the quality, especially for the price. I used some cumaru deck boards I had around (a tough, dense rot-resistant tropical hardwood- from a sustainable plantation, of course) and galv. angle material for intermediated frame supports (visable in the photo with the deck folded up, and some 3/4" treated plywood pieces I had in the barn for decking. I added a galv. angle strip across the back, to protect the deck when running stuff on and off, and installed a supply of d-rings and hooks for tie down. I also went to the trouble of putting the wiring in looms, and better securing it and sealing it to avoid lighting issues. I like the design that lets you fold the trailer up so it doesn't take up much space- handy when you only use it 3 or 4 times a year, at most. Of course, it isn't for hauling CUTs around, but for the uses I have, behind a Subaru Forester, it seems perfect.
/ Cheap, servicable trailer #2
Looks good, what size are the wheels and tires?
/ Cheap, servicable trailer #3
That's a nice little set-up, nice job. :thumbsup: And kudos to the clean shop/working area...mine always seems to look like a bomb went off in it. :D
I was going to mention, it has 12" wheels, 4.80-12 tires. Rated for 785 lbs each. I figure the trailer weighs about 350 lbs, so I won't be putting more than a 1000 lbs max. on it. I liked the idea of being able to pivot the trailer down from the A frame, makes loading stuff easy.
/ Cheap, servicable trailer #5
Nice Job! I like your garage floor, what paint is that?
/ Cheap, servicable trailer #6
$223 including the axles, springs and tires?..If so, holy cow!!..Can't beat that even having to supply your own deck...That fold up feature is nice..Is that all based on leverage or is there a lock mechanism...Can't tell from the pictures...
Nice job!!!!
/ Cheap, servicable trailer #7
I got the best man in my wedding the same thing. He was always borrowing my trucks and he had a Subaru Impreza WRX. I got the trailer and hitch for him back then for right at $300. He has not used my trucks since.
I did do a bearing job on it for him 2 years ago. It was tough to find the seals so get 2-3 sets now while you have time. I ordered them through HF but it took a few weeks to get them.
He has added as spare tire and has taken that little trailer as far as 1000 miles from home with no issues.
Chris
Murphy- the garage floor finish is a two-part epoxy which I applied when the concrete floor was about a month old- I just etched it with muriatic acid and rinsed, then rolled on the paint like the directions said, and I have been 100% happy with it for the past 12-13 years. Paint and glue comes right up, and the inevitable spill when changing oil wipes up nicely, too. Sweeping up chips and what not is easy!
I will get a set of axle seals- that's good advice, but I don't use the trailers much more than 100 miles a year, so they should last? And $223 (well, plus tax) was everything but the deck stuff and D rings, but everything from lights to hitch otherwise. Folding it is a bit of manual work, maybe too much for one old guy, but easy enough for two. I think you would need a hook or chain or something to keep the back half in place folded up, but the A frame just hangs. Two hitch pins release the A frame, and you should have a couple of bolts to keep that back half from bouncing going down the road- I am thinking about a couple of pins with clips for that purpose, but it comes with bolts/lock nuts. If I just park it ready to go, I will use the bolts. Garage floor space is at a premium.
/ Cheap, servicable trailer #9
Seals rot due to the environment, not miles. Just the nature of grease on rubber.
We did pins in his after the first few trips. No issues.
Chris
/ Cheap, servicable trailer #10
You might want to look into 13" rims and tires for it. A lot of those 12" tires are only rated for 55 mph. (check the side walls for info)
You are right- the booklet even states that, in fact. Not a problem for me, since I will just use it for trips to the transfer station and Home Depot, etc. and not the interstate.
/ Cheap, servicable trailer #12
Looks like one of the best deals around. Varmint my friend your to modest. Love what you did with it. For the cost you can't go wrong and your improvements made it invaluable. Cool stuff my friend and thanks for posting it.
Looks like I need to clean up my shop now after looking at yours :eek:
/ Cheap, servicable trailer #13
lot of the guy in the BMW club use those to tow behind there track cars. Run street tires to the track. On the trailer is 4-6 track tires tool box popup tent, cooler etc.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59906)
2016 FREIGHTLINER...
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
2012 Honda Crosstour Hatchback (A59231)
2012 Honda...
2021 Honda Pioneer 700 4x4 Gas Utility Cart (A59228)
2021 Honda Pioneer...
1998 Chevrolet Step Van Food Service Truck (A59230)
1998 Chevrolet...
2025 Hydraulic Brush Cutter Mini Skid Steer Attachment (A59228)
2025 Hydraulic...
