Cheap nuts and bolts - where?
   / Cheap nuts and bolts - where? #11
A TON. ha ha ha. Are they all the same size?:eek::D
As the others said, best deals around here are the farmers coop or TSC. We have a retail chain called Home Hardware (like Ace) that sells by the pound too. They are all quite competitive on pricing.
Many were ASTM graded industrial rated in both metric and standard up to maybe an inch or so diameter by six-eight inches long. Lots of grade five coated common sizes, big flat and lock washers, etc., etc.
It was all left over hardware from industrial installations with big ductile iron pipe, high pressure and high vac applications. I had to spend a couple of days sorting but it was worth it.
I just cannot seem to get around to selling some off, lol!
I am waiting patiently for the day when they install more equipment. The space is there covered with big steel plates just right for making a welding table.
FWIW, I used to find good hardware at yard sales and flea markets. Buy it and sit on it until the day you need it. Also, way back when, an employer talked the local Granger store into setting up an "employee account". You paid up front but got the business discount.
   / Cheap nuts and bolts - where? #12
Fastenal
if more people knew about them there wouldn't be a hardware aisle at Lowe's.
   / Cheap nuts and bolts - where? #13
mcmaster carr
order today by noon here tomorrow by 5:00
tom
   / Cheap nuts and bolts - where? #14
Typically need to order by the box (100 each). Then they are pretty cheap. Its fine for nuts, washers and nylocks. Bolts a bit trickier due to all the different lengths. Last 22RE engine rebuild I did was about $120 just to replace all the rusted fasteners, but I will NEVER put crappy fasteners back on an engine that I may have to work on again in the future..
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2018 Kenworth T680 Tri- Axle Dump Truck (A55788)
2018 Kenworth T680...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
202327 (A54756)
202327 (A54756)
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
