Cheap nuts and bolts - where?
   / Cheap nuts and bolts - where? #1
Travelover
Elite Member
Washington
B7100
I live about 30 minutes from the nearest Tractor Supply, so I stopped into Lowes to get 25 5/16 x 1.25" bolts with nuts and flat washers. I couldn't believe the total cost was ten bucks.
Call me a cheapskate, but this seems excessive. :eek:
Anyone have another source for less expensive fasteners?
   / Cheap nuts and bolts - where? #2
I'm not sure 40 cents for each for a bolt, nut and washer is excessive. Tractor Supply is probably a little cheaper.
   / Cheap nuts and bolts - where? #3
do you have Ace or True Value hardware anywhere close?
They're not as cheap as TSC, but still sell bulk bits & pieces by the pound.
   / Cheap nuts and bolts - where? #4
Our local farmers coop has about the same prices as TSC on nuts and bolts.
Lowe's must figure their customers don't know any better.
   / Cheap nuts and bolts - where? #5
TSC sells nuts and bolts by the pound.
The cheap nuts and bolts are $1.99 a pound...You can also get different size washers for $1.99 a pound.
I'm stocked up very well on all sizes. :D
   / Cheap nuts and bolts - where? #6
Guess I made out okay then when I bought about a ton of surplus bolts, nuts and washers by bid for 150 bucks? I figured I would sell some off at a flea market or something but then you never know what you are going to need, ha!
   / Cheap nuts and bolts - where? #7
I bought lag screws at a hardware store out in the country cheaper than I can get them at Lowe's. JC
   / Cheap nuts and bolts - where? #8
Ace doesn't sell by the pound here. The various grades at TSC priced by the pound are a pretty good deal. Whenever I stop in I buy a couple of pounds of various fasteners to keep on hand. I hate running all the way to the store for a dang single bolt:(
My big regret was when TSC quit selling Metric fasterns by the pound, if I'd have known they were gonna do that I'd have bought a hundred pounds, you'd think with all the imported tractors they'd have kept on;)
   / Cheap nuts and bolts - where? #9
A TON. ha ha ha. Are they all the same size?:eek::D
As the others said, best deals around here are the farmers coop or TSC. We have a retail chain called Home Hardware (like Ace) that sells by the pound too. They are all quite competitive on pricing.
   / Cheap nuts and bolts - where? #10
I just wish TSC had the lock-nuts by the pound.
I had to buy the lock-washers.. and I have 4lb. of them:D
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A43003)
2019 KENWORTH T680...
2014 Ford F-450 Liftmoore 5000W Mechanics Crane Truck (A44571)
2014 Ford F-450...
2001 Ford F-250 Ext. Cab Pickup Truck (A44572)
2001 Ford F-250...
1957 Rogers 35ft T/A Detachable Lowboy Trailer (A44571)
1957 Rogers 35ft...
2018 GMC Savana (A44501)
2018 GMC Savana...
LINE LOCATOR (A45333)
