Cheap lake home? May or May not happen. (It is a go!)
   / Cheap lake home? May or May not happen. (It is a go!) #242
You and your helpers should be proud, the place looks great! summer will be here before you know it. All the hard work is soon to pay off.
Mike
Thanks guys! I am going to have to take a week off due to my real paying job and the coffers are pretty low.
My son with the railroad is working a quarry not far from Gaston. He was given a quote of $1200 delivered for 25 Tons of what they call ballast.
It looks good for what I need. My sons boot is the gauge he provided.
   / Cheap lake home? May or May not happen. (It is a go!) #245
Ballast makes for a good roadbed....nice work
   / Cheap lake home? May or May not happen. (It is a go!) #246
Have you used an electric meter to check continuity?
I only had a voltage tester pin. I called the electrician that solved my other problem and he will come by next week. If I have a cut or nail, I will have him tell me and then I will run the new line.
   / Cheap lake home? May or May not happen. (It is a go!) #249
Looks nice with the pots and pans hung up.
2013 Chevy Silverado 2500 HD (A53472)
2013 Chevy...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53472)
2012 RAM 5500...
