Day 35
Mar 15, 2022 / Cheap lake home? May or May not happen. (It is a go!) Thread Starter #91 OP hcallaway Platinum Member Joined Oct 9, 2003 Messages 654 Location Richmond VA Tractor New Holland TC33D, Ford 3600 Day 35 https://imgur.com/a/ubolwcT
Mar 15, 2022 / Cheap lake home? May or May not happen. (It is a go!) Thread Starter #92 OP hcallaway Platinum Member Joined Oct 9, 2003 Messages 654 Location Richmond VA Tractor New Holland TC33D, Ford 3600 Day 36 https://imgur.com/a/2zGdnOO
Mar 15, 2022 / Cheap lake home? May or May not happen. (It is a go!) Thread Starter #93 OP hcallaway Platinum Member Joined Oct 9, 2003 Messages 654 Location Richmond VA Tractor New Holland TC33D, Ford 3600 Day 37 https://imgur.com/a/WgSvO2s
Mar 15, 2022 / Cheap lake home? May or May not happen. (It is a go!) #94 EddieWalker Epic Contributor Joined May 26, 2003 Messages 25,260 Location Tyler, Texas Tractor Several, all used and abused. Why are you running PEX through the walls?
Mar 15, 2022 / Cheap lake home? May or May not happen. (It is a go!) Thread Starter #95 OP hcallaway Platinum Member Joined Oct 9, 2003 Messages 654 Location Richmond VA Tractor New Holland TC33D, Ford 3600 No I used the old HVAC duct system and then on top of the insulation between the floor joists. I ran them through cutting the floor from above rather than from under the trailer.
Mar 15, 2022 / Cheap lake home? May or May not happen. (It is a go!) Thread Starter #96 OP hcallaway Platinum Member Joined Oct 9, 2003 Messages 654 Location Richmond VA Tractor New Holland TC33D, Ford 3600
Mar 15, 2022 / Cheap lake home? May or May not happen. (It is a go!) Thread Starter #97 OP hcallaway Platinum Member Joined Oct 9, 2003 Messages 654 Location Richmond VA Tractor New Holland TC33D, Ford 3600
Mar 17, 2022 / Cheap lake home? May or May not happen. (It is a go!) Thread Starter #98 OP hcallaway Platinum Member Joined Oct 9, 2003 Messages 654 Location Richmond VA Tractor New Holland TC33D, Ford 3600 Day 38 https://imgur.com/a/zQ3kLqn
Apr 16, 2022 / Cheap lake home? May or May not happen. (It is a go!) Thread Starter #99 OP hcallaway Platinum Member Joined Oct 9, 2003 Messages 654 Location Richmond VA Tractor New Holland TC33D, Ford 3600 Day 39 https://imgur.com/a/M92vYKX
Apr 16, 2022 / Cheap lake home? May or May not happen. (It is a go!) #100 EddieWalker Epic Contributor Joined May 26, 2003 Messages 25,260 Location Tyler, Texas Tractor Several, all used and abused. Did you take a break from working on this?
