Cheap Drill Bits
/ Cheap Drill Bits #11
I have that same set of bits in a wood box.
They work fine except the grabbing.
And you need to use plenty of oil.
And if you got a lot of holes to drill use bi metal hole saws.
I drilled about 30 one inch holes so far in 1/4 and 3/8 plate so far.
And the bit shows no signs of dulling yet. I use plenty of oil.
I got a nice set of TiN bits from walmart for $17.
1/16 to 1/2 with 3/8 reduced shanks all in a nice case.
Pooh Bear
/ Cheap Drill Bits #12
shvl73 said:
I was using my cheapo TSC drill press. The lowest speed is 260rpm. I used a small 1/4" pilot drill, then stepped up in increments to 15/16". The press has a small amount of run-out and when I tried drilling the large holes in one step, they ended up off and I had to weld them solid again. Starting small and stepping up seemed to keep better accuracy. For $139.00, the press works well. The spindle loosened up a couple of times and when I tried to set it using the table with a block of wood with down pressure (per directions) the table mount broke. The manager at TSC replaced it with a part from his floor model on the spot. I thought that was good of him. I then used a block of wood and a 3lb hammer and tapped it up into place. It seems to hold better that way.
When it falls out again and it will, try cleaning the tapers with brake cleaner or another good degreaser, then using some medium strength Loctite.
I also bought a set of the cheap S&D drills from Harbor. I have the set in the wood case. So far I've drilled one 3/4" hole in a piece of 1/2 mild steel and it was fine.
/ Cheap Drill Bits #13
shvl73 said:
I bought these HF drill bits with a bit of skepticism but, they worked well. I was drilling 3/4" steel plate and using some penetrating oil as I drilled.
[FONT=arial, sans-serif]Harbor Freight Tools - Quality Tools at the Lowest Prices[/FONT]
Yes, those are good drills at a great price. I've used them, and they cut and last just great.
Their cobalt drill set (1/32-1/2") is also fantastic, as is their "grab bag" of seconds. I rather use a fine quality drill that is .002 out of spec than a crummy drill that is exactly right.
What you have to watch is "alloy" drills and sorry drills with titanium nitride (gold color) plating. Putting TiN plating on a sorry drill will not make it work or last a bit longer. You can't put lipstick on a pig.
/ Cheap Drill Bits #15
Good advice. If you use Loctite be very careful and apply to only a small area on the big end of the taper since a broad coverage area of, even weak, Loctite may make it very difficult to remove if you ever want to. The taper is self locking and should actually be adequate w/o the augmentation. You will need a sharp blow to set it tho - more like what would tranfer thru a piece of regular steel shielding the chuck from the direct hammer blow. Wood gives too much cushion and prevents a good set.
larry
/ Cheap Drill Bits
Thanks for the advice guys. I'll use it when the chuck/spindle loosens again.
/ Cheap Drill Bits #17
Larry is right.
However personally, I would not use any loctite.
I would make sure the tapers are free of burrs or bumps by running some Emory cloth or even a file while chucked up in the lathe just get rid of the bumps or burrs. Then use acetone to clean both male and female tapers. Those tapers are locking tapers and should not disengage through normal use. The need to fit perfectly all around.
I set mine against a piece of mild steel with the jaws completely retracted. Then I take the quill while the chuck is running and tap the drill chuck into the mild steel with a "snap" to it. That is like a sharp blow to seating it. I do that a couple times to be sure it is set squarely with no run out. It should take a similar sharp blow in the opposite direction to unseat it.
Just my two cents...:)
/ Cheap Drill Bits #18
I'd agree on the Loctite if these weren't low cost imported machine tools we were talking about. The tapers should be locking dry.
But I tried everything else. Cleaning, deburring, setting repeatedly with a deadblow, etc. All the things that would have worked on something with properly sized and cut tapers didn't work on mine. The Loctite finally did.
I suppose there's a reason I could buy a 16 speed floor standing drill press with a decent 5/8" chuck and a lowest speed of 195 RPM, all for $129. Quality and precision probably aren't on the list... ;)
Mine's Ok though. It's solid enough and even with the taper issues the spindle runout is acceptable.
/ Cheap Drill Bits #19
Well, I suppose you're right about that as a last ditch effort.
The important thing is to get it working after all, so whatever ends up working is a good thing, right? I've had to do some tweaking on the cheap stuff I bought too...just to male it work. The quality is just not there in those low price items.
Sometimes it's perfect and sometimes it's a POS.
2020 ASV RT65 (A60462)
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
