Cheap chainsaw sharpener Einhell BG-CS 85 E
   / Cheap chainsaw sharpener Einhell BG-CS 85 E #1
Metsaman
Europe / Finland
Massey Ferguson
This kind gadget I bought in this week, quite cheap to buy ( 32,90 USD ) and seems to do good job... least better to Me in hand file.. :ashamed:
   / Cheap chainsaw sharpener Einhell BG-CS 85 E #2
They work well, have an Oregon sharpner, easy to take to much.
Seems to be so, both tooths on chain are similar... hard to get that by hand especially if chain are damaged...
   / Cheap chainsaw sharpener Einhell BG-CS 85 E #4
Be careful -- the cheap ones usually have enough slop that they can easily ruin a chain! They are not repeatable, so you can't get the same sharpening from cutter to cutter.
   / Cheap chainsaw sharpener Einhell BG-CS 85 E #5
For an accurate and repeatable resharpening, a TimberLine is your best bet. I use mine in the field (with a bar vise) all the time.
Yes.. I notice that but it makes also sharpening work flexible, just take what needed... nothing more..
   / Cheap chainsaw sharpener Einhell BG-CS 85 E #7
I use one too. They're worth the money.
I just watch Youtube video on that tool... handy I have to say.. !! :thumbsup:
   / Cheap chainsaw sharpener Einhell BG-CS 85 E #9
They ship worldwide too. No reason not to have one even if you don't live in the USA. Mine really works well, you only remove as much tooth as necessary.
   / Cheap chainsaw sharpener Einhell BG-CS 85 E #10
That's true! A friend bought a cheap one from Princess Auto when it was on sale and one immediate improvement was made by replacing the loosey goosey pivot shaft with a bolt that was a very close fit. We also did a bit of grinding on one piece to give it a larger radius to allow the chain to pass over it more smoothly.
MANTIS 155B LOT NUMBER 230 (A53084)
MANTIS 155B LOT...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2018 JOHN DEERE 5075GN LOT NUMBER 100 (A53084)
2018 JOHN DEERE...
