Cheap carry-all
/ Cheap carry-all #1
Root Cause
Platinum Member
North Carolina mountains
Mahindra 2638
Cobbled this 1st cross member last night. It can be improved for sure but good enough for prove of concept. I will add posts to hang gloves to dry and will add canopy once the cross beam is right. Used it all morning and no steaks or issues. Not heavy weight and need a better phone holder. It will look better when painted. Also, use cotter pin to last piece that holds it on ROPS to easily remove.
Hoping others here can make it better.
/ Cheap carry-all
Try it again
/ Cheap carry-all #8
I think there's some confusion as to the definition of a "Carry-All" here.
/ Cheap carry-all #10
Yep, there are many types, here is the Carry-All that I bought from Omni MFG.
/ Cheap carry-all #11
I laughed so hard I almost wet myself. The socket wrench did it for me. :ROFLMAO:
/ Cheap carry-all
Is this a scheme your kids rigged up?
Yes but this is the 2nd one. The first one was made of 3" angle iron, cost $400, and weighed 300 lbs. to carry the 8 lbs of tools I need to clear an acre of land with chainsaw, backhoe, and tractor. Thanks for asking. They are excited that you knew!
/ Cheap carry-all
I know. Keeping the tools I use most often close by makes laugh too. If you have issues wetting yourself, my kids could probably rig up something for the Depends. :)
/ Cheap carry-all #15
I bolted a receiver hitch carry all to the ROPS, works great, cost about $75 total.
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A59911)
2005 MACK CXN613...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
