Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,861
Something of an alternative. I currently have my $25/mon Visible sim in my Nighthawk MR1100. Being a Hotspot, speed is limited to 5mbs. It uses Verizon signal and I have in a spot my Mobley only gets about 3mbs.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,862
Is that still the only option you have. That seems slow for todays interweb.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,863
Put that Mobley SIM into a Netgear LB1120 with a Nighthawk router behind it and I think you will see the speeds greatly increase. I typically see 30 down and 10 up. You will need the PUK Codes do do it though
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,864
Think we have an antenna site that location, trees blocking. Mobley used to do much better that location. I might get to try using a Yagi antenna to help in a couple weeks.
This is my other Mobley about 300 away, better view
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,865
I just got a Nighthawk mr1100 lte mobile hotspot router and the speed improved from our Verizon dsl some but not by a large amount. Download speeds from3 mbps to around 20 mbps on occasion but the upload speed is usually less than 1 mbps, it seems that the faster the download the slower the upload, why?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,866
Curious
Anyone aware of a method to transfer Mobley? I have 2 accounts I’m getting ready to turn off, but if their is a way for someone else to benefit…
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,867
Curious
Don’t know.
I’m keeping mine for the price, I’ll put it at dads house before I get rid of that deal.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,868
Do you have an external antenna on it? I do not have the mobley plan, but I have the MR1100. I have one external antenna. It has helped a lot. I have been told if I put two on it of set to 45 degrees I will get even better signal because of the polarization.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,869
Tried to activate online, first one asked for my Onstar car number, I told her she was not in the right connected car plan, got transferred several times, finally got to the right person but she could not verify me since I didn't have my drivers license number handy. After a total of 57 minutes on the phone, she assigned a cell phone number and a eighteen digit case number and said go to the AT&T store.
Took the eBay/Besy Buy Mobley to the AT&T store in Stillwater yesterday. Megan met us at the door, sat down at a table and in about 15 minutes had it activated. She said I might get Billing to wave the $25 activation fee. Total monthly bill will be $25.94 with all of the extra fees.
Got home, plugged it in to the power supply, It works! :D Got a weak signal of -115 dBm, 130 kbps down, 10kbps up.
Speed increased when moved to a stronger signal, this is -106 dBm:
And -100 dBm:
Kinda slow, but faster than Hughes Net in the evening hours. 👍
Still have a lot of places to try for a stronger signal.
Well after 6 years of continuous use I disconnected the Mobley from the battery on Monday.
These were some of the fastest speed tests here in the house with the Mobley:
Now using a Verizon Gateway model WNC-CR200A:
And some speed tests:
Not as fast as Starlink, but fast enough for my wife and I.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,870
View attachment 832422View attachment 832424
Just curious, how much per month. Both Verizon and ATT are slow at our place so it probably wouldn't work for us.
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
New Idea 483 Round Baler (A50774)
New Idea 483 Round...
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
HEAVY DUTY QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
HEAVY DUTY QUICK...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
