Midniteoyl
Elite Member
- Joined
- May 20, 2013
- Messages
- 4,766
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
Something to note for those with the Nighthawk MR1100 (4g) is that the WiFi on it really sucks. You might get good signal to the tower, but unless you run it through the Ethernet port to another WiFi router or WiFi hotspot, it will max out at about 40mbps and limit the number of attached devices (to 6 or 9, I think).
Mine runs to a switch, then to several devices via Ethernet cable and a EXT7000 hotspot. 19 connected devices and 120-220mbps speed, depending. I only have the 2.4Ghz radio on in low power as a way to connect to the router in emergencies.
