Chattering QA palte - One Fix
   / Chattering QA palte - One Fix #1
SwampmanLA
Someone posted a fix for the noisy chatter of the QA plate when mowing. That fix consisted of three bolts and tapped holes at the top of the QA plate. He said it worked fine to quiet down the chatter but was a little hard to switch between between attachments. Sorry but I can't find the link or remember who wrote it. Well that got me to thinking................
Why not use the locking dogs of the QA assembly to pin the QA plate tightly to the tractor. The dogs move out the way to provide clearance for swapping attachments and it works for all your attachments. So what I cane up with is two steel wedges welded on the dogs. Have a look as the work great.
Swamp
   / Chattering QA palte - One Fix #2
Sounds like and looks like a good idea. I can't think of any negatives. Please update us as you gain experience with using it.
   / Chattering QA palte - One Fix #3
Swamp
Hey swamp, that was me. Ive since stopped using two of the bolts because it made it tempermental hooking up.
I did however take the same idea as you used except instead of rigging the quick attach , on each individual attachment i installed two 3/8" set screws through the attachment and then while the attachment is mounted, adjusted the set screws to take up slack pushing the quick attach tabs snug to the slots....tough to explain , idid it to the LMB and the mini hoe.
The reason i chose to work it on the attachment end rather than the quick attach end like you did is i didnt want to rely on every female attach plate being exactly the same.
Kris
   / Chattering QA palte - One Fix #4
That looks pretty cool. Where did you source the steel? Seems like thick piece....
   / Chattering QA palte - One Fix #6
   / Chattering QA palte - One Fix #7
Great job! I have the same issue and I had thought about doing this or putting a layer of industrial belting on the attachments that aren't snug.
I did have one concern about wedging the Q/A plates, which was that the wedges might loosen, because there would be active pressure driving the Q/A cams to loosen. What do you think?
Since you are doing the experiment, it will be interesting to see if it causes you any issues.
Thanks for sharing the fix; it is great to see these creative solutions!
All the best,
Peter
Swamp
I am happy to say that my PT mowing is MUCH less noisy. Matter of fact, now that the QA plate noise is gone I found that the spacer rings on the front wheels were almost as bad at making noise. That was easy, I took them off and stored them in the tool box, noise eliminated! For a quieter ride, something like this is a must do.
Swamp
   / Chattering QA palte - One Fix #9
I wear shooting muffs when mowing. Don't hear a thing. :rolleyes:
   / Chattering QA palte - One Fix #10
thanks alot guys.
now I am embarrassed when I mow... never realized that all the clanging was due to the QA plate.
Drove by a neighbors house one morning at 0600, and someone (professional) was out mowing with a zero turn mower that was so quiet that I couldn't even here the motor from 20' away.
Guess I will have to unpack the welder, wire up some sort of outlet for it (ust moved), and work on that QA mod and exhaust mod. After I get the boat in the water (new house has a dock...)
1996 International Water Truck with a Caterpillar Engine (A53472)
1996 International...
BAUMA LIGHT TX 12 LOT NUMBER 224 (A53084)
BAUMA LIGHT TX 12...
2018 JOHN DEERE 5075GN LOT NUMBER 90 (A53084)
2018 JOHN DEERE...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
CHAMPION 1 PERSON GAS EARTH AUGER (A51248)
CHAMPION 1 PERSON...
Kubota M6800 (A50123)
