Chattering in hydraulic lines on 7520
   / Chattering in hydraulic lines on 7520 #11
SpiderD65 said:
Iv'e lurked on this forum since my purchase of a two wheel drive 7520 with a FEL in August 07, but this is my first post. I need help. The rear hydraulic outlets are controlled by levers that have a raise position, lower position, and then a float position. When I move the lever from lower to float I get a chattering noise in the hydraulic lines coming into the stalk for the FEL. I first noticed this while using a batwing mower.
The tractor just came back from my dealer where it has been for about three weeks for this problem. The service manager tells me they have changed the hydraulic filter, cleaned the screen, raised and lowered the FEL numerous times to clear air in system, if any, cleaned and abraded fittings and double clamped them, ran pressure tests on hydraulic pump and probably other tests that escape my mind. He stated that the Mahindra rep that he was working with said that all 7520's make a chattering noise when hydraulic lines are not hooked up to the outlets, but no chattering occurs when lines are hooked up.
My question is this, do any of you that own a 7520 ever notice a chattering in your hydraulics when moving your lever to the float position? Does any chatter occur with or without hydraulic lines plugged into the rear outlets? Thanks in advance for any assistance.
I have no experience with your tractor but if you have done all the tests you say ...Some tractors do it ,Case IH MX's are buggers for it ,Whining ,Howling and chattering ...no real problem,They do it from new ?
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
1996 International Bucket Truck (A50323)
1996 International...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51244)
UNUSED FUTURE 20'...
1994 Alumatech Frameless Dump Trailer (A50514)
1994 Alumatech...
2003 FORD E-350 (A50323)
2003 FORD E-350...
1988 CATERPILLAR 815B PADFOOT LANDFILL COMPACTOR (A51242)
1988 CATERPILLAR...
