chatter from loader when lifting
   / chatter from loader when lifting #1
daniel33
westwood ca 96137
Ford 335
My Ford 335 tractor has a Bucket loader and Gannon scraper. Loader will lift full height and the oil is full in the rear end, but it chatters and hesitates.So sometimes I have to move control valve to get it to lift, but it still chatters and will go all the way up. Is it in the control valve or the pump that operatesd the lift??
   / chatter from loader when lifting #2
Chatter as rocks in a can or marbles in a tube.
That sounds like cavitation.
A relief valve will squeal/ whine.
External load checks may chatter as the pressure tries to overcome the load pressure.
   / chatter from loader when lifting #3
I am not a self-proclaimed hydraulic expert like some...... But here is my stab at whats going on.
Is it a constant issue after the tractor has warmed all the way up or just when you just start working the loader when everything is not warm yet? Does it only do it at an idle or all threw the r.p.m range?
It sounds like cavitation to me. But either from cold, thicker oil not getting threw a filter/screens fast enough when cold, OR a filter/ suction screen that is in need of changing or cleaning not letting enough oil threw at all.
Again, I am not a self-proclaimed expert on hydraulic issues like some..... Its been my experience that when pumps go bad they either get so weak do to wear everything tied to it gets real slow....but then sometimes a pump will implode or sometimes pumps explode. Valves do funny things but your issues do not sound like a valve to me, but I am not there to listen or watch offending problem.
Again, I am not a self-proclaimed expert on hydraulic issues like some..... If it were my tractor, I would start by draining the oil, changing the filter or cleaning suction screen refill with some fresh oil and see what that would do. If that did not help, I would find out where and how to test pump pressure and go from there.
   / chatter from loader when lifting #4
Although I am not an expert either, you might install a hyd gage in the IN port of the loader in a tee and monitor and trouble shoot the hyd system.
Other experts might chime in here and help solve the problem .
Clean the suction screen if the tractor has one and let us know the condition of the screen.
Relief should be around 2100 psi.
   / chatter from loader when lifting #5
Does it lift if you feather the control so it lifts very slow? If yes you probably have a quick disconnect that is closing due to excessive pressure drop caused by increased flow. Try putting the fel on the ground and releasing all the pressure in the lines and then disconnect and reconnect the lines.
   / chatter from loader when lifting #7
I am an expert,
Ex being a has been
Spert being a drip under pressure :)
   / chatter from loader when lifting #8
Whoops, I'm sorry. Welcome daniel33 to TBN.:welcome:
Lots of GOOD stuff here:thumbsup: TBN has got everything from people that want to learn to people that actually "know" and some that don't, key board jockeys, a captain obvious club and a few grumps, chumps. Even REAL LIFE farmers:eek: All of which share there knowledge in all associated with owning, operating and using/operating tractors and related implements on a year 'round basis to those wishing they had more seat time.:soapbox:
Thankyou - I am checking out the relief valve!
Thanks for your welcome information. I am going to start with the hydrolic pump. However, on the left side of the tractor I see the pump to the engine with a easy to change filter attached. Next to it I see the hydrolic pump. There is no visable external filter /screen that I can see. I have the manuals and still cannot locate where the filter/screen is. Any suggestion!
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A53421)
2017 Caterpillar...
2012 CATERPILLAR 259B3 SKID STEER (A52705)
2012 CATERPILLAR...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
