Charging System
/ Charging System #1
IndianaBill
I am a new owner of a JD750, a Yammar in green paint, and am having a problem with the charging system. The charge light stays on and the battery runs down over time. Does anyone have basic info about the system? In particular, what kind of generator/alternator do I have? I find two wires comming out which seem to be one winding and no sign of a field winding. There is also a 6 pin regulator on the fire wall. Does anyone have a schematic?
Also, what is the eqivalent Yammar model?
Thanks.
/ Charging System #2
You should get around 25 AC volts if you connect a meter to the 2 wire out of the alternator. You will probably get that voltage, and that would point to the regulator which we stock.
Thanks,
Bruce
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2019 GENIE S-80XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-80XC...
Rhino SE8 Rotary Cutter (A64047)
Rhino SE8 Rotary...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2022 Kubota 74in. Hydraulic Dual Cylinder Grapple Skid Steer Attachment (A61567)
2022 Kubota 74in...
