Charging Issue-2520
   / Charging Issue-2520
   / Charging Issue-2520 #12
I'm betting on a failed battery... hope you find the problem.
And I don't get die-hards anymore. Went that route and it "failed" to perform. ;)
   / Charging Issue-2520 #13
Poster had told us battery was good in first post
   / Charging Issue-2520 #15
Also after doing a little research it seems the 2520 model has two different engine configurations a later one with glowplugs/timer module and an earlier version with the manifold heater. Seems no one can pinpoint when exactly the changes occurred at least not by serial number but its widely assumed that 2008 and later are GP. but some say it may go back to 2006 model. So there is a slightly grey area there. OP said tractor was a 2007
Accordingly the engine number is the way to know for sure.
The 3TNV82A-BMJK engines use Glow Plugs
The 3TNV82A-MJK and -MKJE engines use Air Intake Heaters
DFB-Thx-will pass on. He did push some snow last night and it did not crap out
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A55973)
2022 Power Screen...
Test Button (A55272)
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
6' SCRAPE BLADE (A52708)
6' SCRAPE BLADE...
