Charge light on at high rpm off at low
   / Charge light on at high rpm off at low #1
wesmann
Western Massachusetts
YM 276D
My ym276 charge light has flickered for a month. Now it's on at working speeds all the time but off at low rpms. Too cold to tinker right now so I put a charger on it if I have to. Any suggestions on what to look at first when it gets warm again? I did tighten the belt a bit but no luck.
   / Charge light on at high rpm off at low #2
I would check voltage at battery with tractor running to start with. Then go from there depending on what you find.
   / Charge light on at high rpm off at low #3
Do you have the YM276 Service Manual? See Section 40.10 & 40.11.
If you need the manual, it's FREE with many others at the Yanmar Tractor Owners Group.
main@yanmar-tractor-owners.groups.io | Home
   / Charge light on at high rpm off at low #4
Possible light is on because it's overcharging at higher roms? Turn headlights on and check battery voltage at different roms. If it's over 14.6 volts it's overcharging. Perhaps regulator is stuck on? Is there staining on top of battery or is battery hot after use...sign of overcharging system.
Thanks for the tip on the Yanmar Owners Group. I will check it out.
   / Charge light on at high rpm off at low #6
Yes, it's always worth thinking about overchanging. Today overcharging is more likely to be a problem with some battery types and voltage-sensitive components. I wouldn't be surprised to find that modern voltage regulators are capable of reporting overcharging as a fault condition.
But on these older ones - there were several different old style regulators - but none of them had the ability to report overcharging back to the operator. The old regulators could reduce the voltage in a couple of different ways, but they did it invisibly.
So the lamp flicker isn't an overcharging message, but that doesn't mean that the regulator hasn't broken down and is allowing overcharging. As you say, that is still worth checking with a voltmeter. Also check for AC vs DC voltage at the battery. These old Yanmars were built back in an era when overcharging was less of a problem. All we had as a chargng target for energy storage were vented lead/acid wet cell batteries mounted out in the open. That type system is less affected by too high of a charging voltage. Or at least not in the same way that the modern gel, AGM, and litium batteries are.
rScotty
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
HAND TRUCK & MT. FURY ROADMASTER BICYCLE (A58374)
HAND TRUCK & MT...
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58216)
8 TOOTHED BUCKET...
3PT SPIN SPREADER FRAME (A52708)
3PT SPIN SPREADER...
KING KUTTER SCOOP PAN (A52708)
KING KUTTER SCOOP...
