Changing Transmission Oil on JD 4500
   / Changing Transmission Oil on JD 4500 #1
MMH
Murrysville, PA
JD 4500
I was reviewing my operators manual and surprised to see that the transmission oil is to be changed every 200 hours - is this correct? I have the PowrReverser transmission. The manual lists Type F automatic transmission fluid as being acceptable. Anybody running Type F? I'll probably end up using Tractor Supply Universal Tractor Fluid (which indicates that it meets the JDM J20D).
   / Changing Transmission Oil on JD 4500 #2
You could put in a synthetic and get an oil analysis done. You dont want an oil that only meets the specs, but also exceeds the specs.
How much is JD oil?
   / Changing Transmission Oil on JD 4500 #3
Id trust about any name brand. As for the JD fluid, i a sure it is adequate but I prefer to stay away from OEM lubrication products when possible.
   / Changing Transmission Oil on JD 4500 #4
I have a JD 4700 with the power reverser. I changed the filter at 300 hours and fluid and filter at 600 hours. At 600 hours the fluid looked and smelled just fine. I used premium UTF from NAPA made by Valvoline. I did not have an analysis done but I would wager there was still a lot of life left in that fluid.
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
Electric Mobility Scooter (A51694)
Electric Mobility...
