Changing Tire/Rim Size
   / Changing Tire/Rim Size #1
Dunacn
Furlong
Kubota L3010, Ford 4000SU
I have a 3cyl 4000su with 14.9-28 Ags in the rear. I have the opportunity to pickup nearly new 18.4-16.1 turf tires and rims on the cheap. I have basically retired this tractor to flail mowing about 10 acres of grass and the turfs would be nice. I believe these rims/tires were from an Ford LCG tractor. I know this isn’t an ideal setup, but it gives me something to do. Outside of finding some shorter tires for the front to level things out, is there anything that I would need to do to run this setup?
Thanks!
   / Changing Tire/Rim Size #2
Since that model appears to be two wheel drive you should be good to go with whatever size you put on the rear.
GEHL RT175 GEN 3 SKID STEER (A52707)
GEHL RT175 GEN 3...
UNUSED FUTURE CW59-59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2003 GMC C7500 Utility Flatbed Service Truck (A55852)
2003 GMC C7500...
flooring (A55758)
flooring (A55758)
