Changing seal on front end axle
   / Changing seal on front end axle #1
papahenri123
2008 JD 3720 with cab and a 995 no cab
I have a seal leak - never changed one.
I’d appreciate any thoughts on how to tackle this.
   / Changing seal on front end axle #2
I strongly suggest if you are going to take on the task of repairing your machine you invest in a shop manual for your specific model. They will give you good instruction, not that you will not get some good advice here, but you will have the answer when you need it, not when someone else logs on to their computer.
Likely people will respond here and help out but ultimately, the manual is a time saving and cost saving investment.
   / Changing seal on front end axle #3
I’ve done 3 on my Kubotas. They do fail especially when worked hard. Shop manual was the key to me doing them properly.
   / Changing seal on front end axle #4
You may want to consider doing the other seal.
2011 IHI IC-75 Weld Deck Crawler Carrier (A52384)
2011 IHI IC-75...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
HURRICANE 5' X 10' CONTAINER (A51248)
HURRICANE 5' X 10'...
2013 Volkswagen Passat Sedan (A51694)
2013 Volkswagen...
UNUSED FUTURE D-PDQ 45" LAND LEVELER (A51248)
UNUSED FUTURE...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
