Oil & Fuel Changing Oil question for my IH 574
   / Changing Oil question for my IH 574 #1
dzabloudil
Tipton, IA
IH 574
Being new to this tractor, what oil should I use when I change it? Also, I'm not seeing a normal oil fill cap; do I fill the oil through the dipstick tube?
   / Changing Oil question for my IH 574 #2
Which engine have you got, gas or diesel??
How much do you intend to use the tractor and for what sort of work??, is tractor going to be working hard on say cultivation & or pto work or just tootling around a small at evading??
I have the gas engine. Mostly utility work. I have a loader that I use a little to move some dirt. I have a plow to drag snow from the drive. I have a 5 foot woods mower deck for about 3 acres of pasture grass. When not in use, it stays inside a heated garage.
   / Changing Oil question for my IH 574 #4
Best investment you can make is to buy an operator's manual. It will tell you how to check and fill all the fluids and what to use. It will also give you tune up specs. It will have a lot of other useful information. I just saw a reproduction on Ebay for $26.
   / Changing Oil question for my IH 574 #5
Yes best suggestion is get an operators manual and follow recommendations in that, sorry no experience of gas engines in Europe!!
Ops manual will also show the oil filler!!
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2020 DRAGON ESP...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
2006 APPA TL (A55788)
