changing oil in drives on z-force 54
   / changing oil in drives on z-force 54 #1
proberts
New Holland TT75A
I decided to change the filter and oil in the drive units on my z-force 54 cub cadet. I was able to drain oil and change filters with no problem, however, when I tried to refill the drivbe units (pumps) with oil through the expansion tank as recommended, the oil wouldn't go down. Acts like a air lock. I found the hoses from the tank to the pumps where routed such that it looks like a trap found in bathroom sinks. I cut cable ties to get hoses flattened somewhat and some of the oil flowed down okay. Called the dealer and he said to run the engine so the pumps will suck the oil down. Is this a good idea?
   / changing oil in drives on z-force 54 #2
Well I don't have your tractor but that sounds like good advice to me.
Just "maybe" the oil will flow if just rotate the elevated wheels by hand.
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
City of Lakeland (A51691)
City of Lakeland...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
