Oil & Fuel Changing oil and filters a breeze.
   / Changing oil and filters a breeze. #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I changed the engine oil, filter, fuel filter and air filter. It was all a breeze compared to stumbling efforts before. The fuel filter was especially easy. Got a deep 12mm socket and attached a U joint and then long extension to the U joint. The 12 mm came out with no binding and went back in later with no problems. Once I rotated the fuel filter aseembly up to about perpendicular and above its normal postion, I easily removed the ring holding the filter by hand. I've a little "finger" tool that I use to loosen the oil filter. Bought it at NAPA.
About the only hard part was getting the air filter out and back in because of interference with that upper heater hose. That cover for the air filter WILL NOT go back vertical the way the arrow points. It never has.
Ralph
   / Changing oil and filters a breeze. #2
It always makes me feel good to do my own maintance. It also is great when things go as planned!!!!
SCAN TO RECEIVE TEXT UPDATES (A52708)
SCAN TO RECEIVE...
2018 John Deere 1653 (A56436)
2018 John Deere...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
