Oil & Fuel Changing oil and filters a breeze.
   / Changing oil and filters a breeze. #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I changed the engine oil, filter, fuel filter and air filter. It was all a breeze compared to stumbling efforts before. The fuel filter was especially easy. Got a deep 12mm socket and attached a U joint and then long extension to the U joint. The 12 mm came out with no binding and went back in later with no problems. Once I rotated the fuel filter aseembly up to about perpendicular and above its normal postion, I easily removed the ring holding the filter by hand. I've a little "finger" tool that I use to loosen the oil filter. Bought it at NAPA.
About the only hard part was getting the air filter out and back in because of interference with that upper heater hose. That cover for the air filter WILL NOT go back vertical the way the arrow points. It never has.
Ralph
   / Changing oil and filters a breeze. #2
It always makes me feel good to do my own maintance. It also is great when things go as planned!!!!
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2010 Ford Expedition XLT 4WD SUV (A50324)
2010 Ford...
