Tires changing my first flat tire
   / changing my first flat tire #1
marci
Nebraska
cub cadet 1024
I just walked out to start mowing when I noticed the right front tire of my Cub Cadet lt1024 has a flat..really flat. Since I've only owned the tractor about a month I don't want to wreck something as I attempt to remove the tire. I've spun the hubcap, pulled it, tried to pry it off (without too much force). How do I get that thing off and then what can I expect in regards to removing the tire and wheel. The parts list is not much help to me.
   / changing my first flat tire #2
If the rubber is still good, take the wheel to a tire shop & have them pop in an inner-tube in for you.
G/luck
Joel
   / changing my first flat tire #3
Marci, did you mean an LT1042 instead of LT1024? It's been awhile since I had to remove one of those, but I think you simply have to pry that cap off, and it does take a little force, then you'll find a cotter pin to remove, a big washer to slide off, and then pull the wheel off. And remember, my experience is dated, so I could be way off base.
Yes, you are correct...I must have been a little dyslexic last nite. /forums/images/graemlins/smile.gif I was afraid to put too much force onto that plastic little hubcap but will go ahead and do it this evening. I wasn't sure if there was something on the backside holding it on. Cotter pin I can handle so it looks like it should be pretty staight forward. Thanks for your quick response!
   / changing my first flat tire #5
I got a flat on my 2042 the second time I mowed with it. It was a Russian Olive thorn. I plugged it with one of those tubeless tire repair plugs and it hasn't leaked since. Didn't even have to take it off the tractor that way.
   / changing my first flat tire #6
yeah, but at about 60 mph, it has a terrible shake due to being out of balance. lmao
   / changing my first flat tire #7
I had a multitude of flats when I first moved to our new place. We had several large locust trees (that have since been removed) and mowing around them was dangerous!!!!! I keep my tires filled with Gunk (green stuff you can get at most Home Depot/Lowes) and it works like a charm. In a flat tire just take out the valve stem (each bottle comes with a tool) and put in the whole bottle. Fill the tire with air and give it a spin. I have pulle some VERY large thorn out only to see the holes almost immedieatly filled with green Gunk. No more flats for me.....
   / changing my first flat tire #8
If you have to take the tire off the rim it would be much easier to take it to a mower shop and let them do it.
Because of the small diameter of the tires, they don`t have much stretch.
They are a SOB to get off and on.
I wrestled with one for two hours one time and it finally kicked my butt.
   / changing my first flat tire #9
Leave the tire where it is, go get a bottle of "slime" remove the valve stem core, fill it up with slime, put valve stem core back in, air it up and be done with it
   / changing my first flat tire #10
I'm with Duc on this one, although my favorite product is Fixaflat. I buy it two and three cans at a time. You don't even need to remove the core, just thread it on the stem and it airs/slimes the tire right up.
The only thing I wasn't using it on was car tires because of balance and the mess it caused if you had to dismount the tire. The last slow leak I had, I stopped at three garages and none could check the tire so I injected a can of Fixaflat, that was 8 months ago, no balance issues whatsoever. I'll warn the person changing the tire if I get to that point. I hear it's real messy!
I joke with my brother in law that a true measure of a mans success is how many pneumatic tires he has, I think I'm at 72! There might be a flaw in my thinking!
Curt
BESTWAY LOT NUMBER 39 (A53084)
BESTWAY LOT NUMBER...
UNUSED WOLVERINE U-12-78W 78" LAND LEVELER (A51248)
UNUSED WOLVERINE...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
HURRICANE 5' X 10' CONTAINER (A51248)
HURRICANE 5' X 10'...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
2021 JOHN DEERE 6130R LOT NUMBER 44 (A53084)
2021 JOHN DEERE...
