Changing ignition type
/ Changing ignition type #1
Big Irish
collinsville il.
ford 2000 & ford 900
Can any of you guys tell me what two wires I need to change my ignition over to a push button? Is it one off the hot of the starter and one off solenoid or is it the two off solenoid or what? Ignition switch bad on my Ford 2000 3 cyl diesel and I want to convert. It doesn't have glow plugs, lights or anything else. All input greatly appreciated. mick
/ Changing ignition type #2
The wire that is hot upon the start circuit is the one to connect.
/ Changing ignition type #3
You will heed a hot wire from something to connect to the trigger wire on the solenoid. You will probbaly also need a switch to turn off the circuit to the alternator/generator so that it doesn't kill the battery.
Aaron Z
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A69167)
2014 FREIGHTLINER...
2013 WINSTON AP22024-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
PORTA POTTY (A68842)
Set of 3 Trailer Tires (A66734)
Set of 3 Trailer...
2013 MACK CHU613 WINCH TRUCK (A67714)
2013 MACK CHU613...
HOSE REELS (A68842)
HOSE REELS (A68842)
