Changing hydraulic fluid
   / Changing hydraulic fluid #1
jcummins
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
Bought a tractor recently...and the hydraulic oil is a little milky, so obviously changing it.
Is there an trick to getting ALL the old fluid out, other than just draining it? Got to be oil in the lines, cylinders, etc.
   / Changing hydraulic fluid #2
About the best you can do at home is to lower any implements and force as much fluid back into the sump. If the old fluid is really contaminated you might want to change out, run the tractor for a season, then change fluid again ahead of any schedule. All depends on age and worth of tractor and how **** one might be about maintenance.
   / Changing hydraulic fluid #3
We found with the old 310B JD backhoe it was very hard if not impossible to get it ALL out. We learned we could crack the drain plug and get mostly clear water over and over after a fluid change. After several blown lines then a blown o-ring where we lost so much it quite pulling (effective three fluid change outs it is not so milking a couple years later.
We did add 1/2 gallon of Sea Foam twice (22 gallon of UTF) that did help remove some water but I would only do it if I was going to be running it for 4-5 hours non stop because it requires heat to drive off the water.
We went to Renew from Warren that is covered in the link below since it is to deal with water better.
RENEW Universal Tractor Fluid
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A56858)
2007 Western Star...
JOHN DEERE LOADER LINKAGE (A52708)
JOHN DEERE LOADER...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
2013 FORD TRANSIT CONNECT VAN (A52708)
2013 FORD TRANSIT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
