Changing Hydraulic Fluid on L3240 HST
   / Changing Hydraulic Fluid on L3240 HST
I've never trusted a pump for fluid removal. Just have a hard time believing it removes as much fluid as removing the plugs.
The drain pan I had wasn't going to be large enough for draining the L4240's SUDT2, so I bought a big mortar mixing pan at Home Depot.
Pro's: Has greater capacity than needed / is a huge easy to hit target / slides easily between drain plug locations.
Con's: Can be a bit cumbersome when dumping old fluids into used 5 gallon containers for disposal.
Unlikely the siphon drain from the fill port will remove that much fluid, so removal of the drain plugs will still be necessary.
The mortar mixing pan is a possibilty but as you mentioned it would be somewhat difficult to get the fluid from that pan to the disposal containers. It could also be used to catch any overfill in 5 gal buckets since the buckets would fit inside the mortar mixing pan. However 5 gal buckets don’t fit under the machine without putting it up on blocks.
Based on masscity’s response, it seems likely that It will not exceed the 5 gal capacity of the drain pan I have.
   / Changing Hydraulic Fluid on L3240 HST #12
I bought a storage tote when I did mine. Made sure to get one big enough to hold it all and short enough to fit. The 2 plugs on the rear axle did not yield much fluid. Expect the bulk from the center plug. I would not recommend putting it up on blocks as one poster showed - I am assuming those blocks are stacked loose and not screwed together - as that is just asking for trouble. Since mine is the bigger 5240, it probably has more fluid in it than yours, too.
Then I used a hand pump to transfer the used fluid into the now empty jugs that held the new fluid and brought those in to the used oil place to dispose.
   / Changing Hydraulic Fluid on L3240 HST #13
Please don't assume, they are screwed together as ramps and I drove the tractor up on them. I've done it twice and soon will do it again.
The reason I put it on blocks is, because I use 5 gallon pails and I need the room.
Edit, also in the winter I would drive on to two blocks on the right side to grease the two flanges and later in the year to grease the subframe u-joints. I did this for many years.
I wanted an easier way to grease the flanges, so I talked to my welder-mechanic, he helped me drill two one inch holes in the subframe to grease the two flanges and now it's much quicker.
As far as the safety, I can crawl under my tractor with plenty of room. The height is for the pails only.
   / Changing Hydraulic Fluid on L3240 HST #14
I learned the hard way that a 5 gal drain pan won't hold the hyd. oil from the bottom drain on my old L3430 HST. What a mess!
Since then, I use an oil extractor on the fill plug hole to take out a couple of gallons first before removing the drain plugs.
Likely not the same on your L4240 though.
  • Good Post
Reactions: fc1
Completed the 400 hour service yesterday.
Was able to remove about 2 gals of hydraulic fluid from the fill port using a syphon extractor. Got about 2 1/2 gals total from the two axle drain plugs and close to 5 1/2 gals from the main drain plug on the bottom of the transmission case.
Of the 11.1 gal capacity listed for the machine, we were able to remove a little over 10 gals.
   / Changing Hydraulic Fluid on L3240 HST #16
I took a 150 gallon aluminum fuel tank from a wrecked semi tractor and cut one end off of it with a plasma cutter and Tigged on a pair of aluminum round stock handles so I could move it around. My M9's hold almost 15 gallons of fluid each and the aluminum fuel tank holds it all quite nicely and fits under the tractors with plenty of room to spare.
You can buy aluminum fuel tanks at most truck salvage yards. If one end is damaged it don't matter anyway.
   / Changing Hydraulic Fluid on L3240 HST #17
Once I've drained all the fluid into the aluminum fuel tank, it gets real heavy, so I use an old discarded one gallon plastic jug to get most of it out of the aluminum fuel tank and put it back in the 5 gallon pails the replacement fluid came out of and the remainder at that point, I can dump into one of the 5's and then it either goes into my waste oil tank or to the local Auto Zone which at least here, will take 5 gallons a day for recycling. Not sure about other states and their 'recycling' but here in Michigan at least, most auto parts stores as well as Tractor Supply will accept 5 gallons a day for recycling and the 5 gallon pails make that handy and fairly easy to deal with.
   / Changing Hydraulic Fluid on L3240 HST #18
just get a plastic utility household container @ Wal, etc. was able to get a 60 qt capacity, just enough for my hyd change.
Kubota M5-111 (A53317)
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
8065 (A55852)
8065 (A55852)
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
