Changing Hydraulic Filter at 50 hrs
   / Changing Hydraulic Filter at 50 hrs #1
fixitman123
SE NC
John Deere 1010 LS XR4040
Went to my local LS dealer to get the filters for my 50hr fluid change and asked for a hydraulic filter and the parts guy says you don't need to change the hydraulic filter at 50hrs. I told him the manual calls for it and he said its just a money maker and the Massey's they sell don't call for one until several hundred hours. My tractor is NOT HST it is a geared tractor. Just wondering what everyone's take on this is. Thanks
   / Changing Hydraulic Filter at 50 hrs #2
My take is that if the manual calls for a filter then I would change it at 50h. At some point between my previous 2002 Kubota and now 2016 Kubota the manufacturer no longer recommends changing the hydraulic fluid and filter at 50h... just the filter gets changed. Which is exactly what I will do.
   / Changing Hydraulic Filter at 50 hrs #3
The owners manual for my 2009 M6040 recommend changing ALL fluids, oils & filters at 50 hours.
   / Changing Hydraulic Filter at 50 hrs #4
Follow the manual, record the work and retain the receipts.
   / Changing Hydraulic Filter at 50 hrs #5
Change it all. And get the 'parts guy' to ask tech support about his money maker opinion.
   / Changing Hydraulic Filter at 50 hrs #6
I changed mine also but it was closer to 80 hours. I cut it and inspected it and it looked excellent inside. Pleats were spaced as they were originally and there was no distortion or tears. Oil looked great inside also. I like to change them out just for the fact that there are more wear particles from break in. I found cheaper filters at RockAuto. After buying at the dealers online, they were about $180 for all. I ended up getting them all for around $120 by playing with part numbers and doing some research.
   / Changing Hydraulic Filter at 50 hrs #7
I changed the engine oil and engine filter at 50. Then everything at 100.
   / Changing Hydraulic Filter at 50 hrs #8
At 50 hrs I would change the filters but not the hydraulic fluid unless it was contaminated by water and then you would have bigger concerns to address. The reason for the filter chnage is that during the first 50 - 100 hrs of operation the components are being worn in. The filter catches these particles and potentially fills up. After the first 50 - 100 hrs the wear in or break-in period is over and unless something catastrophic happens the sytem should generate very little contamination allowing the longer time between filter changes.
The oil should be good for 250 hrs unless it gets super hot.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2008 UTILITY REEFER TRAILER (A51222)
2008 UTILITY...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2013 FREIGHTLINER CASCADIA DAY CAB (A51219)
2013 FREIGHTLINER...
