Oil & Fuel Changing HST/Hyd filters and NOT changing fluid.
   / Changing HST/Hyd filters and NOT changing fluid. #1
Buggs67
Veteran Member
Perry Cty, Pennsylvania
Kioti 2014 CK2510 TLB
This may be duplicate information. There was a thread (that I can't find now) about changing filters whie not changing the Hyd Fluid.
One guy said he lost a lot of fluid, like a gallon or more. And made a huge mess. There was a lot of discussion.
Well I changed both my Hyd and HST filers recently and the fluid is not due for a change. I got the tractor warmed up. And used a large plastic cement/mortar mixing "boat" to catch the oil. Before loosening the filters I relieved all the pressure in the bucket and 3 pt. And I only lost about a quart or so of fluid, most of it from inside the filter itself.
   / Changing HST/Hyd filters and NOT changing fluid. #2
I saw a guy on you tube use a shop vac to create a vacuum and change out a leaking oil drain plug on a car and no oil came out. He connected it high up at the oil fill port so he wasen't sucking oil into the vac.
   / Changing HST/Hyd filters and NOT changing fluid. #3
A trick I have used is to plug the breather holes, then park using ramps or a hill to put the filters "uphill". Normally lose a cup or so at most, primarily from the filters as you say. If done with some planning and luck, it can be a pretty quick/easy/clean process.
Case Forklift (A41853)
2022 Kubota SVL75-2 (A40786)
2022 Kubota...
Ransom Slit Seeder (A43158)
Ransom Slit Seeder...
2019 FREIGHTLINER CASCADIA DAY CAB (A43000)
2019 FREIGHTLINER...
2005 Mack CH613 (A41518)
2005 Mack CH613...
Agriquip 40' Shipping container (A43155)
Agriquip 40'...
